Обсуждение эмуляторов
Pinhead2
Модель ресивера: Vu+ zero
Сообщение Pinhead2 » 16 янв 2022, 13:44
добрый день ,как побороть эту проблему wicardd 1.19 skyway light2?
вот конфиг
[global]
active = 1
syslog = 0
log_udp = 192.168.1.11
color_mode = 0
log_rb_size = 51
safelog = 1
debug = 1
[webif]
active = 1
port = 8082
debug = 1
[dvb]
active = 1
filter = dvb1,dvb2
ecm_info = 1
debug = 1
[filter]
name = dvb1
rule = caid=098D;ident=000000;sid!=00C9,00CA,00CB,00CD,00CC,00CE,00CF,00EA,00E9,00E7,00E6,00E8,00EB,0196,01A0,01A1,01A2,01A3,01A4;accept#Sky HD
rule = caid=098C;ident=000000;accept#Kabelkiosk HD
rule = caid=091F;ident=000000;accept#Total
rule = caid=0500;ident=060A00,060C00,042300,041200,050800,041F00,042620,042820,051A00,051A40,051200,030B00,060300,061200;accept#All
rule = caid=0B02;ident=000000;accept#Focus Sat(1°W)
rule = caid=1880;ident=000000,002011,002111;accept#Digi tv
rule = caid=0100;ident=00006A,00006C;accept#CanalDigitaal(23°Е)
rule = caid=0B01;ident=000000;accept #NC+
rule = caid=1884;ident=000000;accept #Canal+
rule = caid=0B00;ident=000000;accept #Kabelkiosk SD
rule = caid=1810;ident=000000;accept#Movistar HD
rule = caid=1803;ident=000000;accept#Cyfrowy Polsat (13°E)
rule = caid=183E;ident=000000;accept#Rai 13e
rule = caid=0D97;ident=000000,000004;accept#UPC Direct 1W
rule = caid=2600;accept=biss #BISS KEYS
rule = next
[filter]
name = dvb2
rule = caid=0648;ident=000000;accept#ORF
rule = caid=0624;ident=000000;accept#Skylink
rule = caid=4AEE;ident=000000;accept#Bulsatcom
rule = caid=0609;ident=000000;accept#Orange SK
rule = caid=092F;ident=000000;accept#Telekom
rule = caid=09BD;ident=000000;accept#Vivacom
rule = caid=1843;ident=000000;accept#HD+
rule = caid=1830;ident=000000;accept#Max 16e
rule = caid=1811;ident=003311;accept#Csat 19e
rule = caid=0629;ident=000000;accept#Pink
rule = reject
[reader]
active = 1
name = emu_key
type = emu
file = /var/keys/SoftCam.Key
debug = 1
[reader]
active = 1
name = NTV
type = newcamd525
account = логин:пароль@server
multiport = port,port
reconnect_delay = 10
force_crypted_cw = 1
keepalive = 120
filter = dvb1,dvb2
debug = 1
лог и пробрема
10:35:41.096 NTV4022: 5 ECM80 (091F:000000/AA1.0) for DVB0[STAPI] not decoded (100/100/100 ms)
10:35:41.096 DVB0[STAPI]: ECM80 (091F:000000/AA1.0) 'N/A' not decoded by NTV4022
10:35:41.106 NTV4014: 2 ECM80 (0B00:000000/AA1.0) for DVB0[STAPI] decoded (113/113/113 ms)
10:35:41.106 DVB0[STAPI]: ECM80 (0B00:000000/AA1.0) 'N/A' decoded by NTV4014
10:35:46.104 NTV4019: 5 ECM80 (0609:000000/AA1.0) for DVB0[STAPI] not decoded (5113/5113/5114 ms)
10:35:46.104 DVB0[STAPI]: ECM80 (0609:000000/AA1.0) 'N/A' not decoded by NTV4019
10:35:46.313 NTV4014: 2 ECM81 (0B00:000000/AA1.0) for DVB0[STAPI] decoded (498/498/499 ms)
10:35:46.314 DVB0[STAPI]: ECM81 (0B00:000000/AA1.0) 'N/A' decoded by NTV4014
10:35:56.301 NTV4014: 2 ECM80 (0B00:000000/AA1.0) for DVB0[STAPI] decoded (495/495/495 ms)
10:35:56.302 DVB0[STAPI]: ECM80 (0B00:000000/AA1.0) 'A1 Broadcasting:FashionBox' decoded by NTV4014
10:36:06.304 NTV4014: 2 ECM81 (0B00:000000/AA1.0) for DVB0[STAPI] decoded (497/498/498 ms)
10:36:06.305 DVB0[STAPI]: ECM81 (0B00:000000/AA1.0) 'A1 Broadcasting:FashionBox' decoded by NTV4014
10:36:08.001 DVB0[STAPI]: STPTI_FilterAllocate: ErrorCode: 2 (ST_ERROR_NO_MEMORY) FilterHandle: ffffffff
10:36:08.165 NTV4011: 6 ECM81 (0100:00006A/FE0.0) for DVB0[STAPI] not decoded rejected (104/104/104 ms)
10:36:08.165 DVB0[STAPI]: ECM81 (0100:00006A/FE0.0) 'N/A' not decoded rejected by NTV4011
понял возниакет после друго эмулятора точнее oscam 11698 под stapi5.
ислам
Модель ресивера: -skyway classic4
Сообщение ислам » 16 янв 2022, 16:59
добрый вечер пожалуйста если есть такой готовый плагин оскам для класика 4 если нужно скину логин пароль буду очень благодарен
Отправлено спустя 1 минуту 6 секунд:
ато уже замучелся не могу настроить только не крути не получаеться
Posts in topic: 63
Сообщение танаис » 16 янв 2022, 17:05
ислам готовый конфиг вам должен предоставить ш@ровод,вы ему за это платите деньги!и чем wicardd не устраивает,конфиг всего один и проще чем у oscam.
ислам
Сообщение ислам » 16 янв 2022, 17:10
если вам не трудно был бы очень благодарен
Posts in topic: 63
Сообщение танаис » 16 янв 2022, 17:15
ислам писал(а): ↑
16 янв 2022, 17:10
конфиг подходит для любого рес-а -> Конфиги для Wicardd.
ислам
Сообщение ислам » 16 янв 2022, 17:24
спасибо и на этом тоже но нужен имено оскам
Сообщение oleg70 » 16 янв 2022, 17:28
ислам
Сообщение ислам » 20 янв 2022, 15:09
добрый день всем вот такой вопрос возможно ли на викарде 19 версии поставить два разных шаравода допустим один нтв 36 а другой кантинент 85 если да то как прописать конфиг подскажите пожалуйста заранье благодарю
Posts in topic: 63
Сообщение танаис » 20 янв 2022, 15:34
ислам писал(а): ↑
20 янв 2022, 15:09
... поставить два разных шаравода допустим один нтв 36 а другой кантинент 85 если да то как...
без проблем,пример:
[filter]
rule = caid=0500;ident=060A00,060C00;accept=vup5000
rule = caid=0B00;ident=0;accept=vip8520
[reader]
active = 1
name = vip
type = newcamd525
account = kackad:kackad@adres.shara.tv
multiport = 8520
debug = 1
[reader]
active = 1
name = vup
type = newcamd525
account = kazak:kazak@192.168.0.104
multiport = 5000
debug = 1
ислам
Сообщение ислам » 20 янв 2022, 16:58
так получаеться просто два ридера прописать и все и фильтр тоже я правельно понел как на вложение
Posts in topic: 63
Сообщение танаис » 20 янв 2022, 17:42
ислам в [фильтр] нужному каид назначаем [ридер и порт] конкретному ш@роводу,можно и ещё проще(в один ридер разместить 2~6 ш@роводов),но это другая тема.
ruslan77
Posts in topic: 61
Сообщение ruslan77 » 11 фев 2022, 10:28
Здравствуйте!!! Подскажите где скачать эмулятор n-cam???
Posts in topic: 80
Сообщение lelik3 » 11 фев 2022, 10:35
Викардд 1.19 для SX 4, SX 6 и SX 6 Pro. Актуален для сегодняшних событий.
plugin.zip
(345.14 КБ) 48 скачиваний
ruslan77
Posts in topic: 61
Сообщение ruslan77 » 11 фев 2022, 10:39
lelik3, оскам и хкам2 и n-cam тоже актуальны!!!!
Отправлено спустя 37 секунд:
lelik3, но мне нужен n-cam
Posts in topic: 80
Сообщение lelik3 » 11 фев 2022, 10:41
На эту линейку я еще не встречал его!
