Прошивка для Formuler Z10 Pro MAX
Z10 PRO Max | GTV
С 15.04.2021 Доступно онлайн обновление ПО
Новая версия прошивки : v10.10.30 Hotfix
Новая версия IPTV MYTVOnline 2 : v10.10.31 Hotfix
Software cannot be rolled back after installation.
Change Log
• NEW: Update to Android security patch level March 2022
• NEW: Implement Private DNS. Access from Android Settings > Network
& Internet menu
• Bug fixes, optimizations, and performance enhancements
MYTVOnline 2 :10.10.31 Hotfix
April 15, 2022
Change Log
• FIX: Portal connection issues
• FIX: Stuttering playback after seeking in timeshift mode
• IMP: Playback issues related to invalid server responses (HTTP 4xx/5xx)
• IMP: Add Estonian language to preferred subtitle/audio list
С 22.09.2022 Доступно онлайн обновление ПО
Новая версия прошивки : v10.10.39 Beta
Новая версия IPTV MYTVOnline 2 : v10.10.38 Beta
Change Log
• NEW: Add external storage format changer
• NEW: Add support for WPA3 security protocol
• NEW: Add USB tuner support for Xbox One Digital TV Tuner (DVB-T)
• FIX: Launcher crash loop
• FIX: Bluetooth paring bug when incoming connections are restricted
• FIX: Unable to switch on Wi-Fi after installing firmware 10.10.36
• FIX: Unable to scan DVB-T2 channels
•IMP: Change default storage type for recording
MYTVOnline 2 :v10.10.38 Beta
September 22, 2022
Change Log
• FIX: Channels missing randomly
• FIX: Menu key not responding on the first connection
• FIX: "No information" in M3U playlist EPG
• FIX: Moves to home screen after sorting channels
Вернуться в «Медиаплееры FORMULER [4K Android 10]»
