Имиджи PKT Hyperion для AX OPTICUM 4K HD51
ИМИДЖЫ AX OPTICUM 4K HD51
Сообщение MrDzhango »
Имиджи PKT Hyperion
Вышла новый релиз PKT Hyperion 6.3 svn3970.
Основные изменения:
- OE-Alliance 4.3
- GStreamer 1.14.4
- Python 2.7.15
- actual base
- current drivers
- [4k] where is posible: HBBTV enabled
- where is posible: KODI enabled
- new packages
- cleared and optimized
- update CPU temperature in InfoCenter and About screen
- update channel list and picon
- automatic instalation E2iPlayer with tools and libs (if free space is avaliable)
- automatic instalation mc and htop (if free space is avaliable)
- remove OpenMultiBoot from image to beter compatibility with other multiboot
- add more remote
- fix CI+
- fix scale picon and key yellow in GraphMultiEPG
- update PKT_VPNSetup and autostart after reboot
- a lot of fixes and updates
Вернуться в «ИМИДЖЫ AX OPTICUM 4K HD51»
