Прошивка версия 1.3.99 FULL
СКАЧАТЬ ПРОШИВКУ 1.3.99 FORMULER Z8
Прошивка для FORMULER Z8
- Admin
С 11.02.2020 Доступно онлайн обновление ПО к всему прочему исправлена работа Wink
Software hotfix for Z8 and Z Alpha has been released. Read the below release notes for the most up-to-date information about the update. Download the OTA software updates directly from your device using the built-in software update app.
Patch Notes:
Firmware Version: 1.4.57
Fixes and Improvements
FIX: No internet connectivity due to IPv6 issue
IMP: Improved UI Optimizations
IMP: Improved Disney+ performance. Install the version from the Market
Bug fixes, optimizations, and performance enhancements
MYTVOnline 2 Version: 7.6.7
New Feature
ADD: VOD Clear History
Clear All watched history: Click the trash can icon on the top of the History screen
Clear single history: Press and hold OK on a VOD item
Fixes & Improvements
FIX: EPG data alignment issues
FIX: Favorited Series Episode list does not update
FIX: Cannot play some m3u
FIX: Cannot parse some xmltv EPG formats
FIX: Split-tunnel VPN doesn’t work
IMP: Remapped toggle VOD favorite button
Press and hold Favorite on the remote to set or un-set favorite VOD
Patch Notes:
New Feature
- Admin
С 11.03.2020 Доступно онлайн обновление ПО
New official update released for Z8 / Z Alpha.
Firmware Version : 1.4.60
MYTVOnline 2 : 7.6.10
New Features, Fixes & Improvements:
ADD: Google Assistant & Voice remote compatibility
ADD: Support for different external physical keyboard layouts (AZERTY)
Change layout from Android Settings > Keyboard > Layout
IMP: 5GHz Wireless channel plan improved
IMP: Enable 24Hz selection from resolution menu (if supported by the TV)
FIX: Certain apps unable to start from the launcher
New Features:
ADD: Auto Frame Rate matching
Turn on AFR from the Settings menu
ADD: VOD Smart Grouping
Turn on Smart Grouping from the Settings menu
ADD: VOD Codec details
Press Info on the remote during playback
ADD: Support for teletext subtitles on non-standard pages
ADD: Support for m3u radio channels
IMP: EPG > choose if catchup EPG data will be populated in the Grid EPG or not.
Toggle from the Settings menu
IMP: VOD > Display more metadata
IMP: VOD > Empty categories are not shown anymore
IMP: VOD > History: Delete single history item
Press and hold OK on a history item to delete it from history
IMP: VOD > Allow jumping to Live TV during VOD playback by pressing Live TV button on the remote
IMP: VOD > save subtitle & audio track preference on resume
IMP: Series > Automatically display same subtitle language in next episode
IMP: Series > Scroll from first to last episode more easily
FIX: Series > Previous subtitle displayed in current episode
FIX: Radio picons not displayed
Bug fixes and performance enhancements
New Features:
- Admin
С 21.05.2020 Доступно онлайн обновление ПО
Firmware Version : 1.4.65
MYTVOnline 2 : 7.8.5
WARNING:
Install and use at your own risk. Software cannot be rolled back after installation.
If serious errors occur, please do factory reset.
The install process and reboot works automatically! Please don`t turn off the box or unplug the power supply, could damage the box. The reboot after update needs always much more time then usual, please be patinate and let the box finish the install.
ADD: Turn off Bluetooth pairing requests
Android Settings > Security & restrictions > Allow incoming BT pairing requests
ADD: Show recording icon in Launcher notification bar when background recording is in progress
IMP: Show active values for IP Settings and Proxy Settings in Android Network Settings menu
FIX: Portal credentials get erased when new remote config is deployed and overwritten
ADD: New User Interface for Live TV
ADD: Favorite Channels editor
Access from Live > Groups > Press LEFT
Add up to 10 different favorite groups
Arrange channels in your desired order
Up to 300 channels per group
ADD: Record one channel, watch another channel for multi-connection XC portals
ADD: Settings > HLS Fast Start ON/OFF
ON: Ramp up from lowest bitrate first
ADD: More Series metadata based on OSD Language
ADD: Direct channel number input from Grid EPG
IMP: Continuous play from Catchup for XC portals
IMP: Removed software update popup for non-essential updates
IMP: Move "View catchup in Grid EPG" option to Portal Settings
FIX: Catchup/Replay bug when local timeshift is enabled
FIX: Displayed fps does not match AFR fps
FIX: XMLTV EPG download issue
WARNING:
- Admin
С 28.05.2020 Доступно онлайн обновление ПО
New official update hotfix released for Z8 / Z Alpha.
WARNING:
Firmware Version : 1.4.67 HOTFIX
FIX: Mouse cursor is displayed when accessing a certain menu
MYTVOnline 2 : 7.8.7 HOTFIX
FIX: Crash when accessing Series episodes
FIX: HLS fast start preference gets reset after reboot
FIX: No EPG for DVB-T channels
IMP: RCU response slow when exiting from Classic channel list
IMP: Added Swedish translation
WARNING:
- Admin
С 28.07.2020 Доступно онлайн обновление ПО
New official update released for Z8 / Z Alpha / Z+ neo.
Firmware Version : 1.4.71
MYTVOnline 2 : 7.9.1
ADD: Official Widevine L1 DRM module
FIX: Problem searching/pairing certain BT devices
IMP: Improved Display Area UX
ADD: New "Skip Ahead" feature for Live TV.
Jump forward to get closer to real-time playback
ADD: Show DVB/ATSC channels in IPTV channel list
ADD: Hide VOD categories
ADD: VOD/Series Online subtitle search
FIX: VOD Player > subtitle end-time issue
FIX: Cloud Timeshift looping issue
FIX: Portal URL trailing slash issue
FIX: ATSC LCN channel numbers
FIX: Group & Favorite buttons not working in VOD poster grid
FIX: Cloud Timeshift not working with certain services
FIX: MOL2 doesn't recognize exFAT formatted media
FIX: Online subtitles: "No Results" when searching for certain languages
FIX: Remote Configuration not re-applied correctly after factory reset or software reset
IMP: Improved Cloud Timeshift compatibility with certain services
IMP: XC API > Smart search. Search without accent characters
IMP: Move between VOD and Series: Press and hold VOD key on remote
IMP: Foreign language Youtube trailers where available
IMP: Improved font for URL and user/pass input
IMP: Youtube trailer playback performance
IMP: Settings menu re-organized
IMP: Live TV > Resolution icons
Improved menu translations. French, Swedish (Thanks pad9k)
- Admin
С 16.11.2020 Доступно онлайн обновление ПО
You spoke and we listened! We have just released new software for Z8 Pro, Z8, Z Alpha, and Z+ Neo.
These release notes provide the most up-to-date information about new features, known issues, and improvements so please read them through for more information.
One of the great things about the new software update is the filter only Favorites on Live. You can access this new function from the classic channel list by pressing the red key on the remote control.
There are also more features that you have always wanted. You can now track progress and resume playback in Recordings and check the added date on VOD.
We recommend users install this update to enjoy better features and more stable functionality.
You can always download the free OTA software updates directly from your device using the built-in update app.
Firmware Version : 1.4.80
MYTVOnline 2 : 7.10.2
WARNING:
NEW: Change system screenshot path. Home > Launcher Settings > Screenshot path
FIX: Z Alpha Bluetooth issue
FIX: Crash fix for some OTT apps
FIX: CEC on/off switch state not saved
FIX: Deployment tools bug that appeared in beta release. (Allow user portals parameter bug)
IMP: Updated system time zones
IMP: NAS mount now visible to other apps
IMP: Rename "HDMI Auto Adaption" & change behavior to "Auto-select BEST resolution"
IMP: Block incoming Bluetooth files. Use Android Settings > Security > Allow incoming BT requests: OFF
IMP: Disconnect and reconnect BT Audio devices without re-pairing
IMP: Updated remote deployment template
IMP: CEC: Wake up TV with Formuler. Wake up Formuler with TV (Must use Standby power mode)
IMP: Memory utilization optimizations
NEW: Live > Filter only Favorites. Activate from Classic Channel List > Filter (Red hotkey)
NEW: Recordings > track progress and resume playback
NEW: VOD Details > Date Added
NEW: Auto-detect API portal from m3u URL
FIX: Danish subtitle display issue
FIX: EPG offset issue with certain services
FIX: Audio Track Language not displayed for some contents
FIX: Menu navigation issue for services with no Live TV section
FIX: Issue with Maximum catchup (replay) days
FIX: picon display issues
FIX: Edit Groups > Cannot select certain Groups
FIX: Online subtitles not displayed immediately after download
FIX: Player controls do not timeout according to OSD Timeout parameter
FIX: Episode list scrolling issue on certain portals
FIX: VOD ends early if paused
FIX: Cannot delete new recordings
FIX: Opus audio playback issue
IMP: Opensubtitles > add all languages
Set preferred languages from Settings > Player Options > Online Subtitles
IMP: Cursor position automatically moved to last watched index in episode list
IMP: Improved Skip Ahead performance
IMP: Scheduled Recordings: Resolve single instance of series conflict
IMP: Warn before powering off if recording is in progress
NEW: Menu Translation: Slovenčina
IMP: Improved Swedish, French Translation (Thanks tvman, GoodGood)
WARNING:
С 07.07.2021 Доступно онлайн обновление ПО
Новая версия прошивки : v1.5.1
Новая версия IPTV : v7.12.1
• NEW: Add MYTV0nline2 channels to the home screen
° Access from: Launcher Settings > Customize Channels
• NEW: Google Assistant integration for MYTV0nline2 Live TV channel search
• NEW: Add USB Tuner Support for Hauppauge WinTV-dualHD DVB-T
• NEW: Add USB Tuner Support for Hauppauge WinTV-dualHD ATSC
• NEW: Add USB Tuner Support for Hauppauge WinTV-HVR-955Q ATSC (2040:b150)
• FIX: Input delay when using cloud gaming services
• IMP: Improved screenshot path selection menu
• Bug fixes, optimizations, and performance enhancements
