Editing MCAS list on PC...
bwe
Модель ресивера: AS4K CI Pro
Japan
Сообщение bwe »
Hello,
I want to edit/add to MCAS. I want to do it on PC, not the MCAS editor. I have the MCAS plugin folder on my PC. Which file contains the list? What software will I need?
Thanks,
BWE
bwe
Japan
Сообщение bwe »
In the plugin_su folder, is the DESCR file where keys are edited/added?
Сообщение MrDzhango »
bwe, good day! To edit EMU keys in CAS on the computer, use the program KeyEdit.
bwe
Japan
Сообщение bwe »
MrDzhango писал(а): 03 июн 2019, 08:43 bwe, good day! To edit EMU keys in CAS on the computer, use the program KeyEdit.
Thank you! :D
bwe
Japan
Сообщение bwe »
Do you have a link to the program? I"m having problems locating it. Thanks. :D
