http://www.mediafire.com/file/qsyk7yo06 ... R.rar/fileChanges
11539nautilus7 8/17/2019, 3:42:21 PM
[dvbapi] Added option to enable/disable ecm.info file creation
Thanks to the guys providing the patches.
http://www.streamboard.tv/oscam/ticket/4738
/trunk/Distribution/doc/html/oscam.conf.5.html
/trunk/Distribution/doc/man/oscam.conf.5
/trunk/Distribution/doc/txt/oscam.conf.txt
/trunk/globals.h
/trunk/module-dvbapi-azbox.c
/trunk/module-dvbapi-mca.c
/trunk/module-dvbapi.c
/trunk/module-webif.c
/trunk/oscam-config-global.c
/trunk/webif/config/dvbapi.html
11538nautilus7 8/17/2019, 3:33:56 PM
[documentation] Whitespace cleanup
/trunk/Distribution/doc/html/oscam.server.5.html
/trunk/Distribution/doc/html/oscam.srvid.5.html
/trunk/Distribution/doc/html/oscam.srvid2.5.html
/trunk/Distribution/doc/html/oscam.user.5.html
/trunk/Distribution/doc/man/oscam.cacheex.5
/trunk/Distribution/doc/man/oscam.dvbapi.5
/trunk/Distribution/doc/man/oscam.server.5
/trunk/Distribution/doc/man/oscam.srvid.5
/trunk/Distribution/doc/man/oscam.srvid2.5
/trunk/Distribution/doc/man/oscam.user.5
/trunk/Distribution/doc/man/oscam.whitelist.5
/trunk/Distribution/doc/txt/list_smargo.txt
/trunk/Distribution/doc/txt/oscam.ac.txt
/trunk/Distribution/doc/txt/oscam.cacheex.txt
/trunk/Distribution/doc/txt/oscam.cert.txt
/trunk/Distribution/doc/txt/oscam.dvbapi.txt
/trunk/Distribution/doc/txt/oscam.guess.txt
/trunk/Distribution/doc/txt/oscam.ird.txt
/trunk/Distribution/doc/txt/oscam.provid.txt
/trunk/Distribution/doc/txt/oscam.ratelimit.txt
/trunk/Distribution/doc/txt/oscam.server.txt
/trunk/Distribution/doc/txt/oscam.services.txt
/trunk/Distribution/doc/txt/oscam.srvid.txt
/trunk/Distribution/doc/txt/oscam.srvid2.txt
/trunk/Distribution/doc/txt/oscam.tiers.txt
/trunk/Distribution/doc/txt/oscam.txt
/trunk/Distribution/doc/txt/oscam.user.txt
/trunk/Distribution/doc/txt/oscam.whitelist.txt
XcamClient3 STAPI based CPU Android 7
- Модель ресивера: Formuler s mini
XcamClient3-11539-r797
odem, Что это?
Ильич, версия эмулятора, которая есть в соответствующей теме.
it is the new version of xcamclient3 , 11539
XcamClient3-11540-r797
http://www.mediafire.com/?bfsldt5ijpv69xc11540nautilus7 8/27/2019, 11:48:37 PM
[dvbapi] SDT parsing optimizations
* The SDT filter is now stopped even if no service name or provide name is found. Previously, on FTA or BISS channels, the SDT filter would run forever.
* The SDT is now used for getting the tsid and onid of the service (in case we haven't already receive them in the CA PMT).
* Duplicate info from the log is removed to keep it clean. The SDT information is only printed once.
* Removed some redundant chekcs from the SDT parsing function. They are already done in the caller function.
* Added more service types as "tv".
The actual string parsing and supported character sets remained the same (still some eastern character sets are not supported).
- satxtreme
- Модель ресивера: OPENBOX AS4K CI PRO PLUS
This oscam is does not support power vu....Only from MAHDI-DZ
does pv channels on astra 4.8 work with oscam from MAHDI-DZ??
IF so ,please give me the working config and softcam
Added in 1 minute 42 seconds:
XcamClient3-11541-r797
https://www.mediafire.com/download/lwbadci2h01u04711541nautilus7 8/29/2019, 3:46:00 PM
[dvbapi] Display service name when zapping
If present in oscam.srvid or oscam.srvid2, the service name is displayed at channel zap (like it was done before the CA PMT rewrite).
- satxtreme
odem, Channels on astra 4.8 work with oscam from MAHDI-DZ
Your build will not work with PVu, because own changes MAHDI-DZ (no public)
XcamClient3-11544-r797_STAPI
http://www.mediafire.com/?w66i3pcrnjdp4jr11544 nautilus7 8/30/2019, 6:20:29 PM
[dvbapi] Added more PMT audio descriptors
11543 nautilus7 8/30/2019, 6:10:45 PM
[dvbapi] Cosmetics and minor optimizations
11542 nautilus7 8/30/2019, 5:54:05 PM
[dvbapi] CAT filtering optimizations
* Separate CAT filter (starting and stopping) from EMM filtering.
* Stop CAT filter as soon as CAT is parsed, instead of letting it run forever. (Everytime we get a new channel, the CAT filter is restarted anyway).
* Split CAT parsing from CA descriptor parsing.
/trunk/module-dvbapi.h
even with MAHDI-DZ build only the audio work and black screen , with my build the key found after about 30 sec and no audio no video , i think we need some correct configurations.
- satxtreme
odem, ...do not write nonsense, with build MAHDI-DZ all good working...I finished
