Hey hi,
Am tuned to that satellite on set up after blind scan the channels did open then went back to Scramble what might be the problem!?
All the plugins on the Decoder are running fine.Am using Formuler s2x!
Kindly may I helped out please.Thanks in Advance.
Intelsat 20 @ 68e - DSTV Tv Package
- oleg70
Please translate the text into Russian ... What channels you watched - it is not clear, there is little information - frequencies or programs. Many are encoded in different encodings. : https://ru.kingofsat.net/sat-is20.php
- Admin
Yumuum3, First, turn off all EMUs except Sirius
Hey hi thanks for the reply...I don't know Russian as a Language so I pray to you to let me use English ok.I have switched off all the rest of the plugins and left Sirius on!And am tuned to 68e DSTV South Africa,7w OSN,7e Azam & StarTimes,36e Zap & DSTV Sub Saharan,5e ZUKU,8w beIN sports & lastly 25e beIN package.Those are the main tv packages receivable via Satellite here in Kenya,East Of Africa.
Kindly if it's possible can they be added on the Sirius Server please..so let me now check if putting all the plugins off and letting only Sirius on let me see if those tv packages will open ok and I'll get back to you ok
Added in 1 minute 56 seconds:
On 68e DSTV the channels started opening then all over a sudden they all went back to scramble..kindly check with the Decryption team in regards to Africa Tv Satellite Packages please...
Added in 2 minutes 15 seconds:
Also 22w Canal + Afrique and 16e Canal + Reunion & Parabola Reunion am tuned it .. so am expecting Sirius Server to be a well capable to Decrypt the Satellite Tv packages I have listed for you.Kindky get back to me as soon as possible ok.
Added in 27 minutes 55 seconds:
https://www.lyngsat.com/packages/DSTV-South-Africa.html
That's the DSTV package Channel list plus Frequencies...thats the one the Decoder started to open up those channels then they all went back to Scramble!!!
Added in 2 minutes 30 seconds:
All the DSTV channels on the Sirius IPTV are of DSTV south africa...can the decoder work as DVB to IPTV!?
Added in 4 minutes 5 seconds:
And last but not the least...how much is the Sirius IPTV and Server renewal cost!?I have been told mine will be running for only 6 months after Purchasing the Formuler s2x decoder!!!
Added in 8 minutes 54 seconds:
Africa Satellite Tv Packages List
1.DsTV @ 68e & 36e
2.Zap Tv @ 36e
3.Canal ± Afrique Tv @ 22w
4.Canal + Reunion Tv @ 16e
5.Parabole Reunion Tv @ 16e
6.TSTV @ 51e
7.Startimes Tv @ 7e & 5e
8.Azam Tv @ 7e
Asia Satellite Tv Packages Receivable Here List
1.OSN Tv @ 7w
2.Yes Tv @ 4w
3.BeIn Sports Tv @ 8w
4.BeIn Tv @ 25e
Check with the Engineering Team to include the above on the Sirius Server
1.DsTV @ 68e & 36e
2.Zap Tv @ 36e
6.TSTV @ 51e
8.Azam Tv @ 7e
1.OSN Tv @ 7w
2.Yes Tv @ 4w
4.BeIn Tv @ 25e
- oleg70
Read IPTV activation here: viewtopic.php?f=119&t=1450
