every software of this device at least for me have a problem where only on HD channles audio will lose sync with picture after a few seconds and will feel like picture is lagging 1 sec or 2 behind audio does someone have a slove for this issue?
it seem to be common with 6605 GX for some reason I have a different 6605 STB and it has the same issue but changing the channel and getting back fixes it completely but on SX1 always lose sync ? any help is appreciated
SX1 audio sync issue
- Admin
Если возникают проблемы с синхронизацией звука, откатитесь на старую версию ПО 2.25
- Admin
проблема на стороне оператора.
- Модель ресивера: -sx1
thank you problem solved in latest fW with some minor changes
