How To Make HD Box 4K Prime Autorole Biss And PowerVU Channels
Peacesat
Модель ресивера: -123
Nigeria
Сообщение Peacesat »
hi dear, I find it difficult for this HD Box 4K prime to opening any biss and powervu encrypted channels. Please help me out! Thanks in advance
Admin
Сообщение Admin »
Satellite 4°W+0.8°W+4.8°E+9°E+13°E+19.2°E, 23.5°E+28.2°E+36°E+42°E, 46°E, 85.2°E
Biss + PowerVU (AU)
SoftCam key
Peacesat
Nigeria
Thanks for the prompt reply. Can you please tell me how to implement this softcam on the HD Box 4K prime. Thanks in advance
Peacesat, You can simply install the Sirius IKS plugin from the DVB plugin feed and PowerVU, BISS and other encodings will work as well.
:arrow: Бонус Sirius CS на HD BOX Prime и HD BOX Prime CI
Peacesat
Nigeria
I did as you prescribed but still HD Box 4K Prime not autorole Biss and PowerVU channels can please explain more?
Added in 2 minutes 39 seconds:
Admin писал(а): 12 апр 2021, 08:27 Satellite 4°W+0.8°W+4.8°E+9°E+13°E+19.2°E, 23.5°E+28.2°E+36°E+42°E, 46°E, 85.2°E
Biss + PowerVU (AU)
SoftCam key
How can I implement this softcam key on the HD Box 4K Prime to achieve my aim? Thanks in advance
Admin
Сообщение Admin »
I remind you that the language of communication on the forum is Russian
There is enough information on the network how to load SoftCam Key into Oscam EMU
Peacesat
Nigeria
I understand you brother but you have to assist us that doesn't understand russian language
Admin
Сообщение Admin »
